Salta al contenuto principale
Dell Vostro A860 RAM Memory Sticks Replacement
Cosa ti serve
  1. Dell Vostro A860 RAM Memory Sticks Replacement, RAM: passo 1, immagine 1 di 2 Dell Vostro A860 RAM Memory Sticks Replacement, RAM: passo 1, immagine 2 di 2
    • With the computer facing down locate the RAM compartment cover.
    • Unscrew the two screws holding the cover to the laptop chassis.
    • The screws do not remove completely, they are clipped into the compartment cover.
    • Lift up on the Memory cover and remove.
  2. Dell Vostro A860 RAM Memory Sticks Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool push outward on both sides of the RAM stick.
    • doing this will release the silver tension clips holding the memory sticks in place. Once released the stick will easily lift up and out of the unit.
Conclusione
Joshua Dennis
Membro da: 03/25/16
528 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 411
