Salta al contenuto principale
Dell Vostro 5560 Memory Module Replacement
Cosa ti serve
  1. Dell Vostro 5560 Memory Module Replacement, Removing The Optical-Disk Drive: passo 1, immagine 1 di 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: passo 2, immagine 1 di 2 Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: passo 2, immagine 2 di 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Memory Module Replacement, Removing the Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Memory Module Replacement, Removing the Memory Module: passo 4, immagine 1 di 1
    • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.953 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 110
