Salta al contenuto principale
Dell Vostro 5560 Hard Drive Replacement
Cosa ti serve
  1. Dell Vostro 5560 Hard Drive Replacement, Removing The Optical-Disk Drive: passo 1, immagine 1 di 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: passo 2, immagine 1 di 2 Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: passo 2, immagine 2 di 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Hard Drive Replacement, Removing the Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive: passo 4, immagine 1 di 1
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  5. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive Connector: passo 5, immagine 1 di 1
    • Disconnect the hard-drive connector from hard drive.
  6. Dell Vostro 5560 Hard Drive Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 204
