Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Pry the base cover along the edges to loosen it.
    • Pry the base cover along the edges to loosen it.
  3. Lift and remove the base cover from the computer.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
  5. Release the tabs that secure the battery in the battery bay.
    • Release the tabs that secure the battery in the battery bay.
  6. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  7. Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
    • Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
36.495 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
18 Membri
1.816 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 127
