Parti
Nessuna parte richiesta.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Pry the base cover along the edges to loosen it.
    • Pry the base cover along the edges to loosen it.
  3. Lift and remove the base cover from the computer.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
  6. Release the tabs that secure the battery in the battery bay.
    • Release the tabs that secure the battery in the battery bay.
  7. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  8. Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  9. Remove the screws that secure the hard drive to the hard drive assembly.
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.786 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 45
Tutti i Tempi: 349
