Salta al contenuto principale
Dell Vostro 500 Memory Module Replacement
Cosa ti serve
  1. Dell Vostro 500 Memory Module Replacement, Removing the Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch toward the side of the computer until it is engaged.
    • Slide the battery out of the bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 500 Memory Module Replacement, Removing the Cover: passo 2, immagine 1 di 1
    • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
  3. Dell Vostro 500 Memory Module Replacement, Popping up the Memory Module: passo 3, immagine 1 di 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.808 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 74
