Salta al contenuto principale
Dell Vostro 3561 Hard Drive Replacement
Cosa ti serve
  1. Dell Vostro 3561 Hard Drive Replacement, Sliding the Battery Release Latch: passo 1, immagine 1 di 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3561 Hard Drive Replacement, Slide the Battery Release Latch: passo 2, immagine 1 di 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3561 Hard Drive Replacement, Removing the Battery: passo 3, immagine 1 di 1
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 3561 Hard Drive Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3561 Hard Drive Replacement, Removing the Base Cover: passo 5, immagine 1 di 1
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3561 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Remove the screw that secures the hard-drive assembly to the computer.
  7. Dell Vostro 3561 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Slide the hard-drive assembly towards the center of the computer and lift it up and away from the computer.
  8. Dell Vostro 3561 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Vostro 3561 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Lift up the hard-drive bracket and remove it from the hard-drive assembly
Conclusione
Johnathan Hammond
Membro da: 02/28/18
45.034 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 210
