Salta al contenuto principale
Dell Vostro 3559 Hard Drive Replacement
Cosa ti serve
  1. Dell Vostro 3559 Hard Drive Replacement, Sliding the Latch: passo 1, immagine 1 di 1
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3559 Hard Drive Replacement, Remove the Battery: passo 2, immagine 1 di 1
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  4. Dell Vostro 3559 Hard Drive Replacement, Remove the Access Panel: passo 4, immagine 1 di 1
    • Remove the access panel from the computer.
  5. Dell Vostro 3559 Hard Drive Replacement, Removing the Hard Drive Cable: passo 5, immagine 1 di 1
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3559 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Lift the hard drive to remove it from the computer [1,2].
  7. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: passo 7, immagine 1 di 1
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.953 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 439
