Introduzione
This guide will walk through all the necessary steps in order to replace the motherboard for the Dell Vostro 3550. This guide may be needed in order to access components connected to the motherboard such as the CMOS battery, fan, and other components. When these components overheat, the motherboard will become damaged and will need to be replaced.
Cosa ti serve
Turn the laptop right side up. Open the display to reveal the keyboard.
Use the metal spudger to pry the keyboard upward from the base. Make sure to pop each of the three clips keeping the keyboard in place.
Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
Lift the access panel up at an angle and remove it from the computer.
Remove the two 5mm Phillips #0 screws that secure the hard drive to the system.
Lift up the hard drive at an angle from the system and remove.
Remove the four 5mm Phillips #0 screws that secure the hard drive bracket to the hard drive.
Remove the five 7mm Phillips #0 screws fastening the aluminum side panels to the laptop.
