Salta al contenuto principale
Dell Vostro 3550 Fan Replacement
Cosa ti serve
  1. Dell Vostro 3550 Fan Replacement, Unlocking the Battery: passo 1, immagine 1 di 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3550 Fan Replacement, Sliding the Battery: passo 2, immagine 1 di 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3550 Fan Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Vostro 3550 Fan Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Vostro 3550 Fan Replacement, Keyboard: passo 3, immagine 3 di 3
    • Turn the laptop right side up. Open the display to reveal the keyboard.
    • Use the metal spudger to pry the keyboard upward from the base. Make sure to pop each of the three clips keeping the keyboard in place.
  4. Dell Vostro 3550 Fan Replacement: passo 4, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 4, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 4, immagine 3 di 3
    • Carefully lift the keyboard upward to reveal the keyboard ribbon cable.
  5. Dell Vostro 3550 Fan Replacement: passo 5, immagine 1 di 2 Dell Vostro 3550 Fan Replacement: passo 5, immagine 2 di 2
    • Lift the black tab on the keyboard cable connector upwards to release the cable.
  6. Dell Vostro 3550 Fan Replacement: passo 6, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 6, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 6, immagine 3 di 3
    • Pull the ribbon cable away from the connector.
    • Remove the keyboard.
  7. Dell Vostro 3550 Fan Replacement, Remove the Screws: passo 7, immagine 1 di 1
    • Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
  8. Dell Vostro 3550 Fan Replacement, Lifting the Access Panel: passo 8, immagine 1 di 1
    • Lift the access panel up at an angle and remove it from the computer.
  9. Dell Vostro 3550 Fan Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the two 5mm Phillips #0 screws that secure the hard drive to the system.
  10. Dell Vostro 3550 Fan Replacement, Removing the Hard Drive: passo 10, immagine 1 di 1
    • Lift up the hard drive at an angle from the system and remove.
  11. Dell Vostro 3550 Fan Replacement, Remove the Screws: passo 11, immagine 1 di 1
    • Remove the four 5mm Phillips #0 screws that secure the hard drive bracket to the hard drive.
  12. Dell Vostro 3550 Fan Replacement, Motherboard: passo 12, immagine 1 di 2 Dell Vostro 3550 Fan Replacement, Motherboard: passo 12, immagine 2 di 2
    • Remove the five 7mm Phillips #0 screws fastening the aluminum side panels to the laptop.
  13. Dell Vostro 3550 Fan Replacement: passo 13, immagine 1 di 2 Dell Vostro 3550 Fan Replacement: passo 13, immagine 2 di 2
    • Turn the computer over and open the screen.
    • Remove the two 5mm Phillips #0 screws to the far right and far left of the motherboard casing.
  14. Dell Vostro 3550 Fan Replacement: passo 14, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 14, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 14, immagine 3 di 3
    • Remove the small ribbon cable connected to the left side of the casing.
    • Repeat this step for the three remaining ribbon cables on the casing.
  15. Dell Vostro 3550 Fan Replacement: passo 15, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 15, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 15, immagine 3 di 3
    • Use the metal spudger to release the palmrest assembly from the rest of the laptop.
    • Lift off the palmrest assembly to reveal the motherboard.
  16. Dell Vostro 3550 Fan Replacement: passo 16, immagine 1 di 2 Dell Vostro 3550 Fan Replacement: passo 16, immagine 2 di 2
    • Remove the small cable connecting the motherboard to the rest of the computer.
  17. Dell Vostro 3550 Fan Replacement: passo 17, immagine 1 di 2 Dell Vostro 3550 Fan Replacement: passo 17, immagine 2 di 2
    • Remove the ribbon cable at the far left that is connecting the motherboard to the screen.
  18. Dell Vostro 3550 Fan Replacement: passo 18, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 18, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 18, immagine 3 di 3
    • Remove the seven 5mm Phillips #0 screws that are fastening the motherboard to the casing.
    • Lift upwards on the motherboard to remove it from the laptop casing.
  19. Dell Vostro 3550 Fan Replacement, Fan: passo 19, immagine 1 di 2 Dell Vostro 3550 Fan Replacement, Fan: passo 19, immagine 2 di 2
    • Flip over the motherboard to access the fan assembly.
  20. Dell Vostro 3550 Fan Replacement: passo 20, immagine 1 di 2 Dell Vostro 3550 Fan Replacement: passo 20, immagine 2 di 2
    • Remove the four 5mm Phillips #0 screws that are holding the fan down onto the motherboard.
    • Remove the three brass 8mm Phillips #0 screws fastening the heatsink to the motherboard.
  21. Dell Vostro 3550 Fan Replacement: passo 21, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 21, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 21, immagine 3 di 3
    • Gently lift the fan assembly and heatsink away from the motherboard, and put it down onto a flat surface.
  22. Dell Vostro 3550 Fan Replacement: passo 22, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 22, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 22, immagine 3 di 3
    • Once placed down, flip the fan casing upside down to expose the bottom shell of the fan.
    • Grab the shell of the fan and pull upwards.
    • Rest the shell of the fan on its hinge to reveal the blades of the fan.
  23. Dell Vostro 3550 Fan Replacement: passo 23, immagine 1 di 3 Dell Vostro 3550 Fan Replacement: passo 23, immagine 2 di 3 Dell Vostro 3550 Fan Replacement: passo 23, immagine 3 di 3
    • Gently pull upwards on the fan to separate the fan from the motor.
  24. Dell Vostro 3550 Fan Replacement: passo 24, immagine 1 di 1
    • Once the fan is removed, gently push the new one onto the motor.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,083
