Salta al contenuto principale
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Cosa ti serve
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, immagine 1 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, immagine 2 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: passo 1, immagine 3 di 3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, immagine 1 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, immagine 2 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 2, immagine 3 di 3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, immagine 1 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, immagine 2 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 3, immagine 3 di 3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, immagine 1 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, immagine 2 di 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: passo 4, immagine 3 di 3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 264
