Salta al contenuto principale
Dell Vostro 3510 Battery Replacement
Cosa ti serve
  1. Dell Vostro 3510 Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell Vostro 3510 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Battery Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Use a Phillips #0 screwdriver to remove the screws highlighted with red circles.
    • Loosen the two 1 mm captive screws (orange circles in the image) on the back corners of the bottom cover.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Battery Replacement: passo 3, immagine 1 di 2 Dell Vostro 3510 Battery Replacement: passo 3, immagine 2 di 2
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of spudger or with Jimmy.
  4. Dell Vostro 3510 Battery Replacement: passo 4, immagine 1 di 2 Dell Vostro 3510 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the battery cable from the motherboard by lightly pulling on the black tape attached to the ribbon cable.
    • The battery cable is the one circled in red.
  5. Dell Vostro 3510 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the 0.1 mm battery screws seen in picture one with Phillips #0 screwdriver.
    • Carefully move the additional sata storage ribbon cable to the side.
  6. Dell Vostro 3510 Battery Replacement: passo 6, immagine 1 di 1
    • Gently remove the battery from the laptop.
    • Be careful with the other ribbon cables.
Conclusione
Jhoan Cruz
Membro da: 02/01/24
483 Reputazione
3 Guide realizzate
Gateway, Team 16-1, Gonzalez Spring 2024 Membro di Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 61
