Salta al contenuto principale
Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement
Cosa ti serve
  1. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Unlocking the Battery: passo 1, immagine 1 di 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Keyboard: passo 3, immagine 1 di 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Keyboard retainer: passo 4, immagine 1 di 1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pry up the Keyboard Retainer: passo 5, immagine 1 di 1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Retainer: passo 6, immagine 1 di 1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pull up the Keyboard: passo 7, immagine 1 di 1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latch: passo 8, immagine 1 di 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Loosen the Screw: passo 9, immagine 1 di 1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Memory Door: passo 10, immagine 1 di 1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screw: passo 11, immagine 1 di 1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Drive: passo 12, immagine 1 di 1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: passo 13, immagine 1 di 1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Optical Drive: passo 14, immagine 1 di 1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: passo 15, immagine 1 di 1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: passo 16, immagine 1 di 1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Rubber: passo 17, immagine 1 di 1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Rubber: passo 18, immagine 1 di 1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: passo 19, immagine 1 di 1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: passo 20, immagine 1 di 1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latches: passo 21, immagine 1 di 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latch: passo 22, immagine 1 di 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Disconnecting the Key Cable: passo 23, immagine 1 di 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Palm Rest: passo 24, immagine 1 di 1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Palm Rest: passo 25, immagine 1 di 1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Sides: passo 26, immagine 1 di 1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screw: passo 27, immagine 1 di 1
    • Remove the screw that secures the WLAN card.
  28. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pull the Card: passo 28, immagine 1 di 1
    • Pull the WLAN card straight out of its socket and remove it.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
Un commento
Thank you so much. It is very helpful!
-Anosh
Anosh Shrestha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 39
Tutti i Tempi: 964
