Introduzione
In this guide, we will show you how to remove and replace the Optical Drive.
Cosa ti serve
Slide the left and the right battery release latches to the unlock position.
Pry up the memory door near the screw hole, lift and remove it.
Gently pry the optical drive out of the computer.
Make sure you have loosen the screw beside the keyboard cable latch, mentioned in the comments of Step 8.
Remove the screws that secure the optical drive bracket.
Remove the optical drive bracket from the optical drive module.
Altre 2 persone hanno completato questa guida.
