Salta al contenuto principale
Dell Vostro 3450 Display Assembly Replacement
Cosa ti serve
  1. Dell Vostro 3450 Display Assembly Replacement, Unlocking the Battery: passo 1, immagine 1 di 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Display Assembly Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard: passo 3, immagine 1 di 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard retainer: passo 4, immagine 1 di 1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Display Assembly Replacement, Pry up the Keyboard Retainer: passo 5, immagine 1 di 1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Display Assembly Replacement, Prying the Retainer: passo 6, immagine 1 di 1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Display Assembly Replacement, Pull up the Keyboard: passo 7, immagine 1 di 1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: passo 8, immagine 1 di 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: passo 9, immagine 1 di 1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 Display Assembly Replacement, Removing the Memory Door: passo 10, immagine 1 di 1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 Display Assembly Replacement, Remove the Screw: passo 11, immagine 1 di 1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 Display Assembly Replacement, Prying the Drive: passo 12, immagine 1 di 1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 13, immagine 1 di 1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 Display Assembly Replacement, Removing the Optical Drive: passo 14, immagine 1 di 1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 15, immagine 1 di 1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 16, immagine 1 di 1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: passo 17, immagine 1 di 1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: passo 18, immagine 1 di 1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 19, immagine 1 di 1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 20, immagine 1 di 1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 Display Assembly Replacement, Release the Latches: passo 21, immagine 1 di 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: passo 22, immagine 1 di 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Key Cable: passo 23, immagine 1 di 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: passo 24, immagine 1 di 1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: passo 25, immagine 1 di 1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 Display Assembly Replacement, Prying the Sides: passo 26, immagine 1 di 1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 27, immagine 1 di 1
    • Remove the screws that secure the display hinge.
  28. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: passo 28, immagine 1 di 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  29. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the LVDS Cable: passo 29, immagine 1 di 1
    • Disconnect the LVDS cable from the system board.
  30. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Wireless Cables: passo 30, immagine 1 di 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  31. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 31, immagine 1 di 1
    • Remove the screws that secure the left hinge.
  32. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: passo 32, immagine 1 di 1
    • Remove the screws that secure the right hinge.
  33. Dell Vostro 3450 Display Assembly Replacement, Lifting the Display Assembly: passo 33, immagine 1 di 1
    • Lift the display assembly and remove it from the computer.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
45.034 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 891
