Salta al contenuto principale
Dell Vostro 3360 Palm-Rest Replacement
Cosa ti serve
  1. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: passo 1, immagine 1 di 1
    • Remove the screw that secures the access panel to the computer.
  2. Dell Vostro 3360 Palm-Rest Replacement, Remove the Access Panel: passo 2, immagine 1 di 1
    • Remove the access panel from the computer.
  3. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: passo 3, immagine 1 di 1
    • Remove the screw that secures the keyboard to the chassis.
  4. Dell Vostro 3360 Palm-Rest Replacement, Prying the Keyboard: passo 4, immagine 1 di 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Dell Vostro 3360 Palm-Rest Replacement, Flipping the Keyboard: passo 5, immagine 1 di 1
    • Flip the keyboard over and lay it on the palmrest.
  6. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Clip: passo 6, immagine 1 di 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  7. Dell Vostro 3360 Palm-Rest Replacement, Display-Hinge Cover: passo 7, immagine 1 di 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Palm-Rest Replacement, Remove the Display Hinge Cover: passo 8, immagine 1 di 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Palm-Rest Replacement, Prying the Rubber Pads: passo 9, immagine 1 di 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: passo 10, immagine 1 di 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the Board Cable: passo 11, immagine 1 di 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the LED Cable: passo 12, immagine 1 di 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: passo 13, immagine 1 di 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Palm-Rest Replacement, Prying the Edges of the Palm-Rest: passo 14, immagine 1 di 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Palm Rest: passo 15, immagine 1 di 1
    • Lift the palm-rest up and away from the computer.
Linea Traguardo
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 204
