Salta al contenuto principale
Dell Vostro 2520 Hard Drive Replacement
Cosa ti serve
  1. Dell Vostro 2520 Hard Drive Replacement, Unlocking the Battery: passo 1, immagine 1 di 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 2520 Hard Drive Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 2520 Hard Drive Replacement, Prying the Tabs: passo 3, immagine 1 di 1
    • Pry up to release the tabs securing the keyboard to the computer.
  4. Dell Vostro 2520 Hard Drive Replacement, Flip the Keyboard: passo 4, immagine 1 di 1
    • Flip the keyboard and lay it on the palm-rest.
  5. Dell Vostro 2520 Hard Drive Replacement, Disconnect the Cable: passo 5, immagine 1 di 1
    • Disconnect the keyboard cable from the system board.
  6. Dell Vostro 2520 Hard Drive Replacement, Remove the Keyboard: passo 6, immagine 1 di 1
    • Remove the keyboard from the computer.
  7. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 7, immagine 1 di 1
    • Remove the screws that secure the bottom base.
  8. Dell Vostro 2520 Hard Drive Replacement, Disconnecting the Cable: passo 8, immagine 1 di 1
    • Flip the computer and disconnect the power board cable and the touchpad cable.
  9. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the screws that secure the palm-rest to the computer.
  10. Dell Vostro 2520 Hard Drive Replacement, Removing the Palm-Rest: passo 10, immagine 1 di 1
    • Starting from the left, pry up the palm-rest and remove it from the computer.
  11. Dell Vostro 2520 Hard Drive Replacement, Remove the Screws: passo 11, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket.
  12. Dell Vostro 2520 Hard Drive Replacement, Lifting the Hard Drive: passo 12, immagine 1 di 1
    • Slide and lift the hard drive and lift it out of the computer.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,052
