Introduzione
In this guide, we will show you how to remove and replace the Memory Module.
Cosa ti serve
Slide both battery latches to the open position.
Slide the battery out of the battery bay.
Loosen the eight screws that secure the memory cover.
Remove the memory cover and set it aside.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the connector.
