Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The battery gives power to the laptop so if your computer is not powering up you will need to replace the battery. This guide will show you how to replace the battery but be careful when replacing it because it can still hold a charge.
  1. Make certain that the power to your laptop is off. Press and slide the two buttons outwards and away from the battery.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Slide the battery away and parallel from the laptop.
    • Slide the battery away and parallel from the laptop.
  4. Remove the battery from the slot.
    • Remove the battery from the slot.
Conclusione
Tangxiao Sun
Membro da: 19/03/2018
425 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 147
