Salta al contenuto principale
Dell Vostro 1510 Memory Module Replacement
Cosa ti serve
  1. Dell Vostro 1510 Memory Module Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery lock to the open position.{2}
    • Slide the battery release latch to the open position. (You may need to hold the battery release latch in the open position while removing the battery.) {3}
    • Slide the battery out of the battery bay.{1}
  2. Dell Vostro 1510 Memory Module Replacement, Memory Module: passo 2, immagine 1 di 1
    • Remove the two screws that secure the memory cover, then remove the cover and set it aside.
  3. Dell Vostro 1510 Memory Module Replacement: passo 3, immagine 1 di 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Conclusione
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 143
