Salta al contenuto principale
Dell Vostro 1500 Keyboard Replacement
Cosa ti serve
  1. Dell Vostro 1500 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: passo 2, immagine 1 di 1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: passo 5, immagine 3 di 3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Vostro 1500 Keyboard Replacement: passo 6, immagine 2 di 2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Vostro 1500 Keyboard Replacement: passo 7, immagine 2 di 2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: passo 8, immagine 1 di 3 Dell Vostro 1500 Keyboard Replacement: passo 8, immagine 2 di 3 Dell Vostro 1500 Keyboard Replacement: passo 8, immagine 3 di 3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: passo 9, immagine 1 di 1
    • Pull the connector toward the screen.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-3, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 975
