Cosa ti serve
Disconnect the battery cable from the connector on the system board [1].
Remove the screws that secure the battery to the computer [2].
Lift and remove the battery from the computer [3].
Lift the tab to disconnect the hard drive cable from the connector on the system board [1] .
Remove the screws that secure the hard drive to the computer [2].
Lift the hard drive from the computer [3].
Altre 4 persone hanno completato questa guida.
2 Commenti
Did work for me, many thanks. Only two small remarks.
a) Why remove the battery? I was installing a SSD in addition to the built in one (the hdd place was still empty). Attaching the hdd cable is possible without battery removal.
b) Disonnecting the battery showed to be a bit tricky. Pulling the cable is out of question, and pulling at the label part looked also not advisable. One-sided prying…not so good. Pushing the connector in the plane of the battery - need to be very careful, slipping may mean impulse force to the cable. I used careful two sided prying into the small spaces left and right of the connector.
Cuál es el tamaño de los tornillos de la cubierta posterior?
