Cosa ti serve
Slide the release latch to release the battery [1].
Remove the battery from the computer [2].
Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
Disconnect the optical drive connector and lift it to remove it from the system board [1].
Remove the screws inside the palmrest [2].
Disconnect the hard drive cable from the connector on the system board [1].
Remove the screws that secure the hard drive assembly to the computer [2].
Lift the hard drive assembly away from the computer [3].
Pull the hard drive cable connector to remove it from the hard drive [1].
Remove the screws that secure the hard drive bracket to the hard drive [2].
Lift the hard drive from the hard drive bracket [3].
