Cosa ti serve
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Release the keyboard by prying on the keyboard release tabs by using a scribe.
Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
Remove the screws inside the palmrest [3].
Pull the clips securing the memory module until the memory module pops up [1].
Remove the memory module from the system board [2].
