Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Slide the release latch to unlock the battery [1].
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the screw that secures the optical drive to the computer [1].
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Release the keyboard by prying on the keyboard release tabs by using a scribe.
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  6. Disconnect the keyboard cable from the system board [1].
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  7. Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  8. Remove the screws that secure the base cover to the computer [1].
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  9. Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
  10. Pull the hard drive cable connector to remove it from the hard drive [1].
    • Pull the hard drive cable connector to remove it from the hard drive [1].
    • Remove the screws that secure the hard drive bracket to the hard drive [2].
    • Lift the hard drive from the hard drive bracket [3].
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.861 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
930 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 19
