Salta al contenuto principale
Dell Vostro 1400 RAM Replacement
Cosa ti serve
  1. Dell Vostro 1400 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 RAM Replacement: passo 2, immagine 1 di 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 RAM Replacement: passo 3, immagine 1 di 2 Dell Vostro 1400 RAM Replacement: passo 3, immagine 2 di 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 RAM Replacement, RAM: passo 4, immagine 1 di 2 Dell Vostro 1400 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  5. Dell Vostro 1400 RAM Replacement: passo 5, immagine 1 di 2 Dell Vostro 1400 RAM Replacement: passo 5, immagine 2 di 2
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
Conclusione
David Hogg
Membro da: 03/20/17
727 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 384
