Salta al contenuto principale
Dell Vostro 14 3468 Hard Drive Replacement
Cosa ti serve
  1. Dell Vostro 14 3468 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 14 3468 Hard Drive Replacement, Optical-Disk Drive: passo 2, immagine 1 di 1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 14 3468 Hard Drive Replacement, KeyBoard: passo 3, immagine 1 di 1
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 14 3468 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  5. Dell Vostro 14 3468 Hard Drive Replacement, Base Cover: passo 5, immagine 1 di 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  6. Dell Vostro 14 3468 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the screws that secure the base cover to the computer
  7. Dell Vostro 14 3468 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 14 3468 Hard Drive Replacement, Hard Drive: passo 8, immagine 1 di 1
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Conclusione
Johnathan Hammond
Membro da: 02/28/18
45.034 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 41
Tutti i Tempi: 6,045
