Parti
Nessuna parte richiesta.
  1. Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
  2. loosen the captive screws on the memory module cover, and then remove the memory module cover.
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.851 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 24
