Salta al contenuto principale
Dell Venue 8 Battery Replacement
Cosa ti serve
  1. Dell Venue 8 Battery Replacement, Rear Case/Midframe: passo 1, immagine 1 di 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Battery Replacement: passo 2, immagine 1 di 3 Dell Venue 8 Battery Replacement: passo 2, immagine 2 di 3 Dell Venue 8 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Dell Venue 8 Battery Replacement: passo 4, immagine 1 di 1
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
Conclusione
Altre 14 persone hanno completato questa guida.
Andrea
Membro da: 02/19/15
1.071 Reputazione
5 Guide realizzate
USF Tampa, Team 9-2, Leahy Winter 2015 Membro di USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 12,397
