Salta al contenuto principale
Dell Venue 8 Back Camera Replacement
Cosa ti serve
  1. Dell Venue 8 Back Camera Replacement, Rear Case/Midframe: passo 1, immagine 1 di 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Back Camera Replacement: passo 2, immagine 1 di 3 Dell Venue 8 Back Camera Replacement: passo 2, immagine 2 di 3 Dell Venue 8 Back Camera Replacement: passo 2, immagine 3 di 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Back Camera Replacement, Back Camera: passo 3, immagine 1 di 1
    • Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
Conclusione
Andrea
Membro da: 02/19/15
1.071 Reputazione
5 Guide realizzate
USF Tampa, Team 9-2, Leahy Winter 2015 Membro di USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,053
