Salta al contenuto principale
Dell Venue 8 7840 Screen Replacement
Cosa ti serve
  1. Dell Venue 8 7840 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: passo 2, immagine 1 di 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: passo 3, immagine 1 di 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: passo 4, immagine 1 di 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: passo 5, immagine 1 di 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: passo 6, immagine 1 di 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: passo 7, immagine 1 di 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: passo 8, immagine 1 di 1
    • Disconnect the connector from the tablet.
Conclusione
USF Tampa, Team 6-5, Remmell Fall 2016 Membro di USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Membri
6 Guide realizzate
3 Commenti
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Replica
Where can I find a replacement screen for this device?
Karim Mohamed - Replica
Is the OLED connected with EDP 30=pin FPC?
Ron King - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,391
