Salta al contenuto principale
Dell Venue 8 7840 Power and Volume Button Replacement
Cosa ti serve
  1. Dell Venue 8 7840 Power and Volume Button Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Power and Volume Button Replacement: passo 2, immagine 1 di 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Power and Volume Button Replacement: passo 3, immagine 1 di 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Power and Volume Button Replacement: passo 4, immagine 1 di 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Power and Volume Button Replacement: passo 5, immagine 1 di 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Power and Volume Button Replacement: passo 6, immagine 1 di 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Power and Volume Button Replacement: passo 7, immagine 1 di 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Power and Volume Button Replacement: passo 8, immagine 1 di 1
    • Disconnect the connector from the tablet.
  9. Dell Venue 8 7840 Power and Volume Button Replacement, Battery: passo 9, immagine 1 di 1
    • Unscrew the eight 7 mm Philips #1 screws.
    • After the screws are unscrewed, you can take off the silver cover.
  10. Dell Venue 8 7840 Power and Volume Button Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect the battery from the tablet.
    • After disconnecting the battery, you can remove the battery from the tablet.
  11. Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: passo 11, immagine 1 di 2 Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: passo 11, immagine 2 di 2
    • Using a plastic opening tool, pry open the left side of the tablet.
    • Locate the power and volume buttons.
  12. Dell Venue 8 7840 Power and Volume Button Replacement: passo 12, immagine 1 di 1
    • Using a plastic opening tool, push out the volume button from the left side of the tablet.
  13. Dell Venue 8 7840 Power and Volume Button Replacement: passo 13, immagine 1 di 1
    Compra
    • Make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the volume button.
    • With tweezers, pull out the volume button.
  14. Dell Venue 8 7840 Power and Volume Button Replacement: passo 14, immagine 1 di 1
    • With a plastic opening tool, push out the power button from the left side of the tablet.
  15. Dell Venue 8 7840 Power and Volume Button Replacement: passo 15, immagine 1 di 1
    • Just like the volume button, you want to make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the power button.
    • With tweezers, pull out the power button.
Conclusione
USF Tampa, Team 6-5, Remmell Fall 2016 Membro di USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 768
