Salta al contenuto principale
Dell Venue 7 Motherboard Replacement
Cosa ti serve
  1. Dell Venue 7 Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 Dell Venue 7 Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: passo 4, immagine 1 di 1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: passo 6, immagine 1 di 2 Dell Venue 7 Motherboard Replacement, Speaker: passo 6, immagine 2 di 2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: passo 7, immagine 1 di 2 Dell Venue 7 Motherboard Replacement: passo 7, immagine 2 di 2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: passo 9, immagine 1 di 2 Dell Venue 7 Motherboard Replacement: passo 9, immagine 2 di 2
    • Gently pull on the wire and remove the speaker.
  10. Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 3 Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, immagine 2 di 3 Dell Venue 7 Motherboard Replacement, Motherboard: passo 10, immagine 3 di 3
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: passo 11, immagine 1 di 2 Dell Venue 7 Motherboard Replacement: passo 11, immagine 2 di 2
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: passo 12, immagine 1 di 1
    • Lift and remove the motherboard from the device.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 11-4, Blackwell Winter 2015 Membro di USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Membri
10 Guide realizzate
2 Commenti
unable to open the lock, can the mother board be changed
Amitabh Mishra - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,443
