Salta al contenuto principale
Dell Venue 7 Battery Replacement
Cosa ti serve
  1. Dell Venue 7 Battery Replacement, Rear Case: passo 1, immagine 1 di 2 Dell Venue 7 Battery Replacement, Rear Case: passo 1, immagine 2 di 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
Conclusione
chaveza
Membro da: 01/20/15
101 Reputazione
1 Guida realizzata
USF Tampa, Team 11-4, Blackwell Winter 2015 Membro di USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Membri
10 Guide realizzate
4 Commenti
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Replica
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 7,402
