Salta al contenuto principale
Dell VRP100 HDMI/USB Cable Replacement
Cosa ti serve
  1. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, immagine 1 di 3 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, immagine 2 di 3 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: passo 1, immagine 3 di 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 HDMI/USB Cable Replacement: passo 2, immagine 1 di 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 HDMI/USB Cable Replacement: passo 3, immagine 1 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 3, immagine 2 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 3, immagine 3 di 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 HDMI/USB Cable Replacement: passo 4, immagine 1 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 4, immagine 2 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 4, immagine 3 di 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: passo 5, immagine 1 di 2 Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
    • Peel off the tape using your hands or the blunt nose tweezers.
  6. Dell VRP100 HDMI/USB Cable Replacement: passo 6, immagine 1 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 6, immagine 2 di 3 Dell VRP100 HDMI/USB Cable Replacement: passo 6, immagine 3 di 3
    • Remove the two 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Hold the HDMI/USB cable and remove from the connection.
Conclusione
Altre 5 persone hanno completato questa guida.
Marco Salazar
Membro da: 10/08/18
375 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G1, White Fall 2018 Membro di Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membri
12 Guide realizzate
6 Commenti
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
jason.d.spiller - Replica
Me too, looking for a cable replacement.
Filipi Nascimento Silva - Replica
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
Tom Powell - Replica
I am also looking for a replacement cable. Could it be soldered on from another cable?
Peter Hindes - Replica
Me too for replacement cable specs please
geebee800 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,529
