Salta al contenuto principale
Dell VRP100 Camera Replacement
Cosa ti serve
  1. Dell VRP100 Camera Replacement, Cover Panel: passo 1, immagine 1 di 3 Dell VRP100 Camera Replacement, Cover Panel: passo 1, immagine 2 di 3 Dell VRP100 Camera Replacement, Cover Panel: passo 1, immagine 3 di 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: passo 2, immagine 1 di 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: passo 3, immagine 1 di 3 Dell VRP100 Camera Replacement: passo 3, immagine 2 di 3 Dell VRP100 Camera Replacement: passo 3, immagine 3 di 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: passo 4, immagine 1 di 3 Dell VRP100 Camera Replacement: passo 4, immagine 2 di 3 Dell VRP100 Camera Replacement: passo 4, immagine 3 di 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: passo 5, immagine 1 di 3 Dell VRP100 Camera Replacement, Camera: passo 5, immagine 2 di 3 Dell VRP100 Camera Replacement, Camera: passo 5, immagine 3 di 3
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: passo 6, immagine 1 di 2 Dell VRP100 Camera Replacement: passo 6, immagine 2 di 2
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: passo 7, immagine 1 di 2 Dell VRP100 Camera Replacement: passo 7, immagine 2 di 2
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
Conclusione
Lauren Monzon
Membro da: 10/08/18
217 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G1, White Fall 2018 Membro di Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 365
