Salta al contenuto principale
Dell VRP100 Auxiliary Cord Replacement
Cosa ti serve
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: passo 1, immagine 1 di 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: passo 1, immagine 2 di 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: passo 1, immagine 3 di 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Auxiliary Cord Replacement: passo 2, immagine 1 di 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Auxiliary Cord Replacement: passo 3, immagine 1 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 3, immagine 2 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 3, immagine 3 di 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Auxiliary Cord Replacement: passo 4, immagine 1 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 4, immagine 2 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 4, immagine 3 di 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: passo 5, immagine 1 di 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: passo 5, immagine 2 di 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: passo 5, immagine 3 di 3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
  6. Dell VRP100 Auxiliary Cord Replacement: passo 6, immagine 1 di 2 Dell VRP100 Auxiliary Cord Replacement: passo 6, immagine 2 di 2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  7. Dell VRP100 Auxiliary Cord Replacement: passo 7, immagine 1 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 7, immagine 2 di 3 Dell VRP100 Auxiliary Cord Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
Conclusione
Chris Grabow
Membro da: 10/08/18
285 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G1, White Fall 2018 Membro di Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membri
12 Guide realizzate
Un commento
Hello, where i can buy the aux cable?
Domenico Rescigno - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 708
