Salta al contenuto principale
Dell VRC100-R Battery Replacement
  1. Dell VRC100-R Battery Replacement, Battery: passo 1, immagine 1 di 3 Dell VRC100-R Battery Replacement, Battery: passo 1, immagine 2 di 3 Dell VRC100-R Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Battery Replacement: passo 2, immagine 1 di 2 Dell VRC100-R Battery Replacement: passo 2, immagine 2 di 2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
Conclusione
Kenneth Liu
Membro da: 04/18/18
169 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G3, Livingston Spring 2018 Membro di Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Membri
5 Guide realizzate
Un commento
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 711
