Introduzione
This guide will demonstrate how to remove or replace the speakers in a Dell Studio 1737 laptop
Cosa ti serve
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
Remove the 8 8mm ph1 philips head screws (red)
Remove also the one 4mm ph 1 philips head screw (blue)
Altre 2 persone hanno completato questa guida.
