Salta al contenuto principale
Dell Studio 1737 Keyboard Replacement
Cosa ti serve
  1. Dell Studio 1737 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Studio 1737 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: passo 4, immagine 1 di 3 Dell Studio 1737 Keyboard Replacement: passo 4, immagine 2 di 3 Dell Studio 1737 Keyboard Replacement: passo 4, immagine 3 di 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: passo 5, immagine 1 di 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Studio 1737 Keyboard Replacement: passo 6, immagine 2 di 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Studio 1737 Keyboard Replacement: passo 7, immagine 2 di 2
    • Remove the ribbon cable as shown
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 692
