Salta al contenuto principale
Dell Studio 1555 Keyboard Replacement
Cosa ti serve
  1. Dell Studio 1555 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Studio 1555 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Studio 1555 Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: passo 3, immagine 1 di 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Studio 1555 Keyboard Replacement: passo 5, immagine 2 di 2
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Studio 1555 Keyboard Replacement: passo 6, immagine 2 di 2
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: passo 7, immagine 1 di 1
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: passo 8, immagine 1 di 3 Dell Studio 1555 Keyboard Replacement: passo 8, immagine 2 di 3 Dell Studio 1555 Keyboard Replacement: passo 8, immagine 3 di 3
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: passo 9, immagine 1 di 1
    • Remove the keyboard
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 926
