Salta al contenuto principale
Dell Studio 1536 Hard Drive Replacement
Cosa ti serve
  1. Dell Studio 1536 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1536 Hard Drive Replacement, Base Cover: passo 2, immagine 1 di 1
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • CAUTION: Do not touch the processor thermal-cooling assembly. Processor components should be removed only by trained support personnel.
  3. Dell Studio 1536 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Remove the four screws securing the hard drive assembly to the computer.
    • Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
    • Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
  4. Dell Studio 1536 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
  5. Dell Studio 1536 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Disconnect the hard drive cable from the connector on the hard drive..
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging. For more information, see "Protecting Against Electrostatic Discharge" in the safety information that shipped with your computer.
Conclusione
Johnathan Hammond
Membro da: 02/28/18
45.058 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 61
