Parti
Nessuna parte richiesta.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Turn the computer over and open the display.
    • Turn the computer over and open the display.
    • Ease the keyboard surround up using your fingers or a plastic scribe.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Lift the keyboard surround off the computer.
    • Lift the keyboard surround off the computer.
    • Remove the two screws at the top of the keyboard.
    • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
    • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
  5. Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
    • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
    • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
    • Lift the keyboard off the computer.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.786 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 19
