Parti
Nessuna parte richiesta.
  1. Slide the battery release latch to the side.
    • Slide the battery release latch to the side.
    • Slide the battery out of the battery bay.
  2. Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the two screws on the hard drive assembly.
    • Remove the two screws on the hard drive assembly.
  5. Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the interposer to detach it from the hard drive.
    • Remove the four screws (two on either side) to detach the hard drive cage from the hard drive.
    • Lift the hard drive cage off the hard drive.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.786 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 48
