Salta al contenuto principale
Dell Streak 7 Headphone Jack Replacement
Cosa ti serve
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: passo 1, immagine 1 di 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: passo 4, immagine 1 di 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: passo 5, immagine 1 di 2 Dell Streak 7 Headphone Jack Replacement: passo 5, immagine 2 di 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: passo 6, immagine 1 di 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: passo 7, immagine 1 di 2 Dell Streak 7 Headphone Jack Replacement: passo 7, immagine 2 di 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: passo 8, immagine 1 di 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: passo 9, immagine 1 di 2 Dell Streak 7 Headphone Jack Replacement: passo 9, immagine 2 di 2
    • Pull the headphone jack up, away from the case.
Conclusione
USF Tampa, Team 4-6, Passmore Fall 2016 Membro di USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 147
