Salta al contenuto principale
Dell Streak 7 Battery Replacement
Cosa ti serve
  1. Dell Streak 7 Battery Replacement, Front Panel Assembly: passo 1, immagine 1 di 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Battery Replacement: passo 3, immagine 1 di 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Battery Replacement: passo 4, immagine 1 di 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Battery Replacement: passo 5, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 5, immagine 2 di 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Battery Replacement: passo 6, immagine 1 di 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Battery Replacement: passo 7, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 7, immagine 2 di 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Battery Replacement, Headphone Jack: passo 8, immagine 1 di 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Battery Replacement: passo 9, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 9, immagine 2 di 2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Battery Replacement, GSM Module: passo 10, immagine 1 di 2 Dell Streak 7 Battery Replacement, GSM Module: passo 10, immagine 2 di 2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Battery Replacement: passo 11, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Battery Replacement: passo 12, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 12, immagine 2 di 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Battery Replacement: passo 13, immagine 1 di 1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Battery Replacement, Motherboard: passo 14, immagine 1 di 3 Dell Streak 7 Battery Replacement, Motherboard: passo 14, immagine 2 di 3 Dell Streak 7 Battery Replacement, Motherboard: passo 14, immagine 3 di 3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Battery Replacement: passo 15, immagine 1 di 1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Battery Replacement: passo 16, immagine 1 di 2 Dell Streak 7 Battery Replacement: passo 16, immagine 2 di 2
    • Lift up the metal cover.
  17. Dell Streak 7 Battery Replacement: passo 17, immagine 1 di 1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Battery Replacement: passo 18, immagine 1 di 1
    • Pull out the motherboard and the battery.
  19. Dell Streak 7 Battery Replacement, Battery: passo 19, immagine 1 di 2 Dell Streak 7 Battery Replacement, Battery: passo 19, immagine 2 di 2
    • Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 4-6, Passmore Fall 2016 Membro di USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,202
