Introduzione
If your speakers seem to be not in the best condition or broken entirely, use this guide to help change out your speakers. You will need a Phillips #0 screwdriver, a plastic opening tool, and tweezers.
Cosa ti serve
Place the device flat on its screen.
Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
Take the segment off and place it to the side.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
