Salta al contenuto principale
Dell Streak 10 Pro SD Card Breakout Board Replacement
Cosa ti serve
  1. Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: passo 1, immagine 1 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: passo 1, immagine 2 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: passo 1, immagine 3 di 3
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 2, immagine 1 di 2 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 2, immagine 2 di 2
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 3, immagine 1 di 2 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 4, immagine 1 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 4, immagine 2 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro SD Card Breakout Board Replacement, SD Card Breakout Board: passo 5, immagine 1 di 2 Dell Streak 10 Pro SD Card Breakout Board Replacement, SD Card Breakout Board: passo 5, immagine 2 di 2
    • Remove three 4mm Phillips #0 screws.
  6. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 6, immagine 1 di 2 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 6, immagine 2 di 2
    • Gently lift up the black covered wire and place it on the side, so that it is not in the way of the procedure.
  7. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 7, immagine 1 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 7, immagine 2 di 3 Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 7, immagine 3 di 3
    Compra
    • When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
    • Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
  8. Dell Streak 10 Pro SD Card Breakout Board Replacement: passo 8, immagine 1 di 1
    • Use two fingers and gently pull the SD card breakout board from its space.
Conclusione
Kayji Arai
Membro da: 02/05/19
211 Reputazione
2 Guide realizzate
UC Davis, Team S20-G7, Lore Winter 2019 Membro di UC Davis, Team S20-G7, Lore Winter 2019
UCD-LORE-W19S20G7
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 101
