Salta al contenuto principale
Dell Streak 10 Pro Rear Camera Replacement
Cosa ti serve
  1. Dell Streak 10 Pro Rear Camera Replacement, Battery: passo 1, immagine 1 di 3 Dell Streak 10 Pro Rear Camera Replacement, Battery: passo 1, immagine 2 di 3 Dell Streak 10 Pro Rear Camera Replacement, Battery: passo 1, immagine 3 di 3
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro Rear Camera Replacement: passo 2, immagine 1 di 2 Dell Streak 10 Pro Rear Camera Replacement: passo 2, immagine 2 di 2
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro Rear Camera Replacement: passo 3, immagine 1 di 2 Dell Streak 10 Pro Rear Camera Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro Rear Camera Replacement: passo 4, immagine 1 di 3 Dell Streak 10 Pro Rear Camera Replacement: passo 4, immagine 2 di 3 Dell Streak 10 Pro Rear Camera Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro Rear Camera Replacement, Rear Camera: passo 5, immagine 1 di 2 Dell Streak 10 Pro Rear Camera Replacement, Rear Camera: passo 5, immagine 2 di 2
    Compra
    • Disconnect the no-fuss ribbon cable connector. Using tweezers, carefully pull the connector straight out of the socket.
    • The white connector is attached to a black wire.
  6. Dell Streak 10 Pro Rear Camera Replacement: passo 6, immagine 1 di 2 Dell Streak 10 Pro Rear Camera Replacement: passo 6, immagine 2 di 2
    • Disconnect the delicate ribbon cable from the Zero Insertion Force (ZIF) Connector.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small black locking flap. Then, you can safely pull the cable out.
  7. Dell Streak 10 Pro Rear Camera Replacement: passo 7, immagine 1 di 2 Dell Streak 10 Pro Rear Camera Replacement: passo 7, immagine 2 di 2
    • Using the tweezer, carefully wiggle off the camera attached to the base.
    • This may take a few minutes. Be gentle while applying pressure.
    • After it wiggles free, lift the camera away from the base of the tablet.
Conclusione
Kayji Arai
Membro da: 02/05/19
211 Reputazione
2 Guide realizzate
UC Davis, Team S20-G7, Lore Winter 2019 Membro di UC Davis, Team S20-G7, Lore Winter 2019
UCD-LORE-W19S20G7
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 101
