Salta al contenuto principale
Dell Precision T3400 Power Supply Replacement
Cosa ti serve
  1. Dell Precision T3400 Power Supply Replacement, Disconnect the DC power cables from the system board and the drives.: passo 1, immagine 1 di 1
    • Pay special attention to where the DC power cables are plugged in so that they can be replaced the same way.
    • You may need to remove the heat-sink assembly in order to detach certain cables.
  2. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: passo 2, immagine 1 di 1
    • Remove the four screws on the back of the power supply using a standard Phillips-head screwdriver.
  3. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: passo 3, immagine 1 di 1
    • Press the secure tab down and slide the power supply out of its bracket to remove it.
  4. Dell Precision T3400 Power Supply Replacement, Install the new power supply.: passo 4, immagine 1 di 1
    • Slide the power supply into the empty bracket. It will click into place.
    • Replace the four screws to secure the power supply to the computer case.
  5. Dell Precision T3400 Power Supply Replacement, Reconnect the DC power cables.: passo 5, immagine 1 di 1
    • Remember to use the case's secure tabs to hold cables out of the way.
    • If you removed the heat-sink assembly in order to remove any power supply cables, be sure to re-install the assembly.
Conclusione
Altre 9 persone hanno completato questa guida.
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 29
Tutti i Tempi: 8,123
